John Dixonhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=512dd1a8af70db0fc52462f7b25121d1A few engine picsTue Nov 21, 2006 9:02 am
Postby
John Dixon »
https://forums.nicoclub.com/john-dixon-u22208.htmlWed Nov 22, 2006 10:43 pm
They do look big. The cams are pretty big overlap and lift (70/30 30/70 @ 50 thou) so the valves more or less chase the pistons down the bores. They've been cut for 2mm min clearence.All the plugs were out when the block was dipped so I think they have been changed.
Postby
John Dixon »
https://forums.nicoclub.com/john-dixon-u22208.htmlThu Nov 23, 2006 12:10 pm
Yes, NA. Don't like forced induction engines, particularly turbos. Wanted that sort of response that you only get from mad revvy NA motors. This is a track day / twisty back road car, not a dragster.
