crzycav86 wrote:if your bov is recirculated, you're supposed to turn off the dec air... dec-air is used for atmospheric bov's.
what's your throttle changeover set at now? you might want to change the interpolation between high and low map so that the changeover is more smooth.(make the low throttle map at higher throttle% and/or make high throttle map at lower throttle%) if your changeover is in the 18-21% range, it might be messing up if it's abruptly changing maps...
ok, so, my bov was atmosphereic before with dec settings, and it would still die like the dec air wasnt even functioning. then I recirced it and took off the settings and it still came close to and died, but not as often.
So, your saying to chnage the throttle hi and low points to keep my cruising throttle point out of the injector changeover range correct? Will changing the throttle settings lean me out considerably and require a retune?
And no BigGame you're thinking of the n62 which cqame from the 300zxTT. If I am correct, the N60 came in the n/a Z32 and Maxima.
