Anyway, after attaching it and running the car for about 4-5 minutes to get the O2 sensor heated up, I noticed the following: starts showing rich (~.95V) then gradually settles around stoich near the lean side (~0.55V) then stays there regardless if I'm at WOT or cruising. Also, when I turn on the accessories such as the wiper, headlights, etc., I see the readings affected (it's showing a drop in voltage).
I thought undet WOT (heavy load) I should see the A/F go rich then settle back to some stoich reading. Also, I thought at cruising speed, I should see the A/F gauge bounce back and forth because the ECM is constanly adjusting. Did I hook the gauge to the wrong wire? do I have a bad ground? do I have a bad O2 sensor (it's relatively new)?
Also, I have a turbo installed on the KA, so I should be shooting for 13.2:1 ratio (~.9V), correct? I heard 12.0:1 ratio from other threads. Hmmm...
Thanks...
