A/F ratio gauge
luis741953
Car: 1995 nissan 240sx se
wazupi bought a autometer air fuel ration gauge, but i dont know how to get to the ignition switch, can you all help methanks
480sx
Car: 1996 Pearl White 240sx
Well, to get to your ignition switch you have to take off the cover that goes around the ignition. You can do so with a Philips head screw driver, its pretty self explanatory.
Secondly, i hate to have to be the one who tells you this, but those things are useless. You bought a narrow band A/F gage, all those things do is give your cabin a light show. Basically, the stock o2 sensor in your car has one function, that is, telling your ECU when your car is at 14.7 A/F. Higher than that, it will read lean. Lower than that, it will read rich. Its completely useless for tuning anything. I would sell it, and save the money for a wideband O2 sensor if i were you, its really not even worth the hassle of installing it.
JP240SX
Car: Nissan 240SX Coupe 1989
do you know any part number of the wideband O2 sensor?? I'm trying to be able to tunne my AFR.
I was thinking on getting this..
http://www.fuelairspark.com/Pr...r.asp
or.. may be. this...
http://www.nolimitmotorsport.com/prod/PLX-M300
any other sugestion I will thank...
480sx
Check out Zeitronix, i chose it becuase it hooks up to a laptop so you can datalog without anything extra. Much faster sampling rate than the LM1 or the PLX. Those are two others you can check.
