A Different Fog light question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
imprezaguy89
Car: 2007 nissan versa sl
Okay, so I am looking to buy the ebay look a like fog light kit. Here it is : http://cgi.ebay.com/ebaymotors/07-10-NI ... 43a83a3366. The set comes with h11 bulbs. I was wondering If I could put in the h8 bulbs and then use the existing wiring harness that comes with the SL versas. Then i Would also need to buy a new head light switch assembly so the fogs are included. Would that work? Thank in advance!
GracelandII
Car: 2011 Nissan Versa S
This is the factory switch http://www.courtesyparts.com/25540-swit ... 61149.html. Some of the kits come with an aftermarket toggle that can be mounted to the left and below the steering column.
Return to “Versa Technical Discussions”
