PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sun Mar 08, 2009 8:29 am
Trying to get the 240 mechanically ship-shape for an upcoming day at the dyno, I pulled the valve cover, installed some heli-coils into stripped bolts, and verified the cam alignment was correct.
It was actually hot out, edging close to 80 degrees. Cold beers were in order.TDC for cylinder 1 on the compression strokeIgnore the marks, they were put there by me a while ago when screwing around with something/ pulling the head.
AFRs seem to be in order- plugs look good.
Now, by this time we were becoming a little inebriated. Efforts to get the fill plug out of the transmission proved futile, so I decided to drill a hole through the B&M shift plate, and my my own damn fill hole.Being super careful to limit the number of chips that fell into the transmission, I drilled a starter hole, then followed with the final size. Even if some chips DID get in there, they are just aluminum, and stand no chance against everything inside (all hardened steel). The bottle of gear oil still wouldn't quite fit down in there, so we grabbed a large straw that we got from a local food joint.
In order to plug this hole up, and use it again, we'd have to tap it. Using the tap in its current form here was NOT going to happen. There was no where near enough clearance for the s***ty Tap design, so I did some quick drunken engineering and decided to weld a bolt to the top of the tap, so that I can use common tools, ratchets, extensions, swivels, etc.I went into my bathroom/laundry room/welding shop, and did a quick drunken weld to the tap... but in my inebriated state neglected to turn the heat up on the welder. We got the tap a little more than halfway in there, and the damn bolt snapped off... leaving the tap stuck in the hole, impossible to get out.So I did what any drunk engineer would do, and dragged the welder outside. Cranked the heat up, and went to town... Space was limited, so we really only got to weld it on 2 sides. I made a bigass doomin verticle weld almost all the way up the bolt, and my friend "tacked" it in place, which I discovered later was just a tack on the bolt... not welding it to the tap... excusable considering we were drunken welding inside a car with our eyes closed.
But hey, it worked, and I now have a fill hole at the top of my shift plate, with a bolt plugging it up.
I also have a badass switch for my electric fan.
