NOTE: my climate control buttons have always been broken. The temp slider had always worked before.
Background on possible relative of problem: About 8 months ago I popped off a intercooler coupler on my s13 blacktop sr no big deal right? Well i got it finger tight back on and drove home without boosting. I got home and fixed the piping and went for a drive and discovered that my temp gauge didn't work anymore. The car ran fine with no noticeable difference so I didn't think much about it.
Current problem: My car has had much more major things being replaced and ive always been throwing all my money and time at those problems, which Im sure most of you can relate to. However I seem to have fixed most of the problems (for now..) and I decided to instead to improve something
Reason for post: Usually my car heats up in less then 5ish min but on this drive all i would get is cold air. The car was driving fine but i didn't get any heat at all. I got on the highway and drove for a while and discovered under constant boost when and when i got on it a little i would get heat, good heat, but as soon as I got off the highway and waited at a light, The heat went away. So i figured this was just a bleeding issue and all i needed to do was bleed the system. I put the front on jack stands as high as i could took the cap off and ran it for 20 min. The rad got hot. The motor got hot and there was some very spaced out bubbles. But nothing changed. still no heat. The car doesn't overheat (as far as i know) and drives like its fine. But with no temp gauge and no heat i have no way to judge whats going on with my car! Please help me out with this. Colorado winters are very cold! I haven't been driving the car for risk of overheating it. Any help would be awesome.
