kuramaya wrote:What Motor are you running? Turbo? What is your low throttle setting at %? Is the DECEL Air setting set? At idel the ECU could be causing it to lean out..You should not worry about adjusting A/F ratio at Idle anyway..unless it is ridiculous. 14 is okay at idle.
edit sorry, see you are in the KAT forum...yeah is your DECEL Air set?
my turbo is a t3/t4 my throttle points are 24/45 dec isnt set since im rec the bypass valve. does it really matter if my car idles in 12's /13's? I think my whole problem may be since i tuned my car on a cold nite, and ive been driving it in the hot days so thats probolly causing it to run rich most of the time i cruse my air fuel ratio jumps from 13's to 14's to some imes 15's, the idle will be from 12's to 14's but my gas milage donst seem that bad should i even worie if its ruing 13's when it should be running 14's? Also i tuned the car when the motor was warm on a cold nite, am i suppost to tune the car with the motor cold on a cold nite? or is it ok to tune at operating temp on a cold nite?
Florida240sx my car also ran bad with the open bov, once i rec it, it ran like a stock turbo car
btw: kuramaya "edit sorry, see you are in the KAT forum..."
i dont even know why i posted there, i get so much moore help on here lol
Modified by AN89HATCH at 10:17 AM 8/1/2005
Modified by AN89HATCH at 11:01 AM 8/1/2005
