a crazy idea
LingeringSuicide
Car: 1990 240SX hatchback 1993 240sx Vert
I'm thinking about dropping an SR20VE with a sr16ve crank and supercharger into my 240. The only problem i can see would be the intake manifold and custom brackets for the supercharger. Yes i also know its a front wheel drive engine so i would have to get an sr20de transmission. Ideas thoughts ect?
Modified by LingeringSuicide at 2:41 PM 12/9/2007
CMG
Car: 1989 240sx Hatch w/ Redtop
Why? And why are you asking here? Obviously people in this section have made the smart choice and just put in the det.
Hijacker
Car: '92 240sx Convertible
'94 F-150
FWD motors will not bolt into a RWD chassis.
I have personally compared FWD and RWD blocks. They are physically different sizes. The trans bolts up different. And the CAS is placed on the rear of the head, which would put it through the firewall in a RWD layout
elgarvo616
Car: 1995 240sx aka sweet thang
most of the time
crazy ideas are pretty stupid
sleepsilvia
Car: 95' 240SX
thats so crazy, it won't work!!!
just stick with the rwd sr.
CMG
Seriously, if ya wanna do something like that, make an sr20ve-t for a 200sx or g20, that's do-able.
T-rev
if you really need a supercharger, there is a supercharger kit for the DET, I think was made by greddy and only found in japan making it way too expensive and hard to find for the power it makes.
If I remember it was like 5 or 6 thousand dollars, considering it can only push <10 psi, you could put all that money into a mean turbo setup, and be a little less unique but kick more ***.
Why would you want a sr16 crank? If you want small displacemnet/high rev you could get a ca18det or rb20det.
