Scooby24 »
https://forums.nicoclub.com/scooby24-u31746.html
Wed Sep 07, 2005 7:25 am
Hey guys I'm just going to get right down to it.
The car: 1997 Auto 240
The swap: S13 transmission w/ harness (not sure if from SOHC or DOHC but it has 4 sensors on it) using a 95 manual ECU
The questions:
1) When putting in the clutch pedal assembly there was an ECU right where the pedal now sits. I unplugged it and think it may be the A/T controller...but not sure...do I need to keep it plugged in? it's going to have to be relocated if so.
2) On my car the rear o2 sensor appears to come from the auto transmission harness...the new harness has no o2 sensor connection. Also I realize I'd need the older 3 prong o2 sensor anyways for 95 ecu. Can I just plug the o2 bung and get rid of the sensor since 95's are OBDI? Do they need that rear o2 signal or can I get by without a CEL?
3) For the non transmission connections on the Harness will they use the same style connectors as the 97 or am I going to have to do some cutting?
Thanks so much for help.
