wirelessalpha wrote:1) you will lose cruise control.
2) Dunno - but if its like that on every other car, thats on every road in the USA - why would you think it isn't?
3) 17's will rub. 18's will rub. Even my 15's rub - due to my lowering. Check not just this forum, but google as well. There are ton's of pro's/con's with wheel sizes, not just limited to 240's. That being said, in my personal opinion - I believe 16's are the way to go.
1. You CAN relocate your cruise control buttons. Do some searching around, as it has been covered before.
3. It doesn't appear that the guy has lowered his car at all. So, 17's and 18's won't automatically rub. I've seen kids fit as large as 19" wheels on their stock height 240sx. However, you will have a VERY short sidewall. With that short sidewall, your ride will be more harsh and your chances of bending/breaking a wheel are greater. You CAN however, fit a decent size tire on a 17" wheel. If you're staying stock height, I'd recommend around a 17x7.5 or 17x8 and a tire between 215/45/17 and 235/40/17, depending on the width of the wheel.
