elwesso wrote:If you baby the car id run the warmer plug range. But if you drive the car hard an/or you drive mostly highway miles (more than 20 miles per crank up average) then I'd say you can run the 6 range....
I dont think the fan will fly apart (never heard of that) but definitely replace it ASAP. I wouldnt remove it.
I dont think you'll ever have to worry about the chains. I dont even think theyll give you any rattling, the altimas used a different motor that had chain issues.
Ill more than likely just stick with the factory heat range. I don't beat on it, and the trips will mostly be short ones, around 15 minutes or so..
I don't think the fan will fly apart either, but it keeps me up at night so ill be changing it asap.
As for the altima, its got the ka24de .. Tough little bastard I tell you. There were never issues with the chain, just the guides that nissan stuck in there then issued a TSB to remove them if they made noise.. hahaha..
I hope this infinity proves to be as reliable as my altima. In all those miles ive just replaced belts, hoses, caps, rotors, wires, plugs, brake pads, filters, a few sets of tires. 1 alternator (it was noisy) , 1 tensioner(noisy) , and the radiator(It had a tiny leak).. Absolutely NOTHING broke on it. ever. Still has its original cat, exhaust and piping, cv axles, bearings, struts, tie rods - etc etc. I never changed the PCV, because you cant get to it.. seriously.. Im telling you that 3k oil changes and 10k drain and refill transmission (4qt) is what kept the car running like NEW. Still no oil consumption, shifts like a DREAM and it makes more power now than it did when I got it with 6 miles on it almost 10 years ago.. The bad though.. It only gets 20mpg in the city, which is pathetic for a 4cyl auto
My 87 300zx turbo gets 25 around town.. vg30et 5 speed I'm guessing the q wont do too much worse. but im not expecting 21 thats for sure.. I drive efficiently, so 16-17??
Thank you all for your help!Could someone report some typical gas mileage in town? (y33 owners only, I know the G50 got worse)
