mcp6530 wrote:Hi,Just picked up a 2006 M35x Nav/Tech with 26,000 miles in chicago area....
Does the vehicle have the ability to automatically lock doors when you walk away from it with the key fob or do you always have to press lock on the key fob? My last car had a key fob and you could just walk away with and it would lock by itself, but I don't know if the M can do that also.
Also, what the heck is centerpoint and autopilot and surround for on the radio?? I just listen to cds/radio/satellite, nothing fancy, no audio dvd's or anything.
Thanks! Love my new M! Except, gas mileage is brutal!!! My Acura TL was 275 HP and I got 30 mpg on the highway. Just took a small road trip with my M and averaged 23 MPG! Ouch!!!
What kind of gas mileage do you guys get?!?!
Welcome to the club. The key doesn't auto lock the doors when you walk away but it does not allow you to lock them in the car either
Audiopilot is a technology that uses a mic under your steering wheel to automatically adjust the audio level for you to compensate for the noises created. Exactly the same way noise cancellation headphones do.
Centerpoint is a technology that involves mixing the audio through the center channel speaker even if it's only stereo. I would turn that option off.
I live in Canada so we're L/KMS and I am averaging 12.5L per 100KMS. When I first bought my 06 M35x I was averaging 13.5L per 100KMS but then I took it in and had them do a fuel system flush (Infiniti dealership only), change the spark plugs, and adjust the idle amount. 1L per 100KMS is not much but I noticed a performance boost which is real nice. Oh and I also changed the engine air filter to the stock Infiniti unit. I wouldn't go with an aftermarket K&N filter as it will attrack more gunk in your engine and muck up the sensors.
CHEERS!
