tunedis95 »
https://forums.nicoclub.com/tunedis95-u10866.html
Sun May 15, 2005 4:38 pm
this is a 90 240sx with a 95 motor and transmission
1-driveshaft is a bit short compared to before...can i use washers and space it back out temporarly. ..WTF
2-when i turn the car on it will idle fine for 20 seconds then bogs down back up to idle and then bog down once again and then go back up to a smooth idle for 20 seconds agan...RECAP idle for 20 seconds, bogs down twice then idle for 20 seconds and repeat
3-my speedomoter and gas gauge work. i know that the tack does not work and thats because i have not swapped that out for the DE gauge....BUT what about the water temp sensor...its not reading anything ....what do i need to check
4-When i drive her the car sputters above 2k rpm and yea...WTF...please help me out you guys, ya got my car this far with previous information...a little bit more....
also the plug right next to the water temp sensor is broken would that have to do with the temp reading.....and i set the timing at 20 degrees..ok...just throwing that out...thats right right???
Modified by tunedis95 at 3:41 PM 5/16/2005
