driftmyke »
https://forums.nicoclub.com/driftmyke-u61159.html
Sun Oct 11, 2009 9:41 pm
ok so i did a rb20 swap into my 93 vert a little over a year, ive got 10,000 miles on it and i still having a idle problem.
first off, i bought the motor as a clip, i had the head resurfaced and had the machine shop check the head for cracks and check the seals, passed both test. i also disassembled the bottom end, to inspect bearings and surfaces as well as piston and cylinder wall condition, all check out good so i reassembled engine with new gasket kit and all new seals. so thats the history on the engine.
when i installed the motor i used a aftermarket front mount intercooler kit, brand new cooler, tubing and couplers with t bolt clamps. the bov is stock and is recirculated using all stock components.
so onto my problem, the motor idles at 1900-2100 when its real cold, after about a minute it will start to fluctuate idle between 1200-2100, going up and down, then after about 30seconds of that it will settle its idle at 1200, and it idles at the rpm from then on, it did this since day 1!
so far i have removed the iacv, cleaned it and reinstalled using new gasket. i have also tried to use the idle adjustment screw on it and it seems to have no affect, right now the screw is completly closed, and it still idles that way. and thats about as far as i have gotten lol.
i have been doing some searching on here and it seems as though the problem could be my timing and or tps sensor. but i dont know how im going to time the engine considering timing is supposed to be checked at idle of 650rpm, mine idles at almost double that, so how should i go about checking the timing? and checking the tps sensor seems to be a pretty confusing task, so im hoping somebody can dumb it down for me, maybe with some pictures? lol. i do have a volt tester so i think i have all tools required?
i also have a few other random questions, i just bought a digital gauge cluster, i have read that it is just a plug and play swap since i have the harness for the cluster? can anybody confirm this? also i am using the tach from my clip in my stock analog cluster right now, but i want to keep the stock 240 tach in my new digital cluster, so my question is how do i modify a stock 240sx tach to read correctly with my rb20?
and now some pics of my car for your viewing please and a thanks for reading my post, keep in mind these pictures were taking a couple days after i finished the swap, so there a little old and the car is pretty dirty, but i plan on taking some new ones when i start fixing this idle problem, so you guys have some better pics to look forward too.
thanks for your time if anybody has any info that could help i would greatly appreciate it.
Modified by driftmyke at 12:46 AM 10/12/2009
