AcMav wrote:My state sadly requires front license plates which would keep me from doing this.I'm hoping you used stainless steel rivets and mesh, I know they sell both stainless and regular rivets. Otherwise you may have problems with rust. I'd be worried about rusting with the hood with the drill holes through it, you should have the entire hood sprayed again to seal it.
MT requires the front plate as well...but the car looks better without them.i got aluminum rivets and the state barely uses salt in the winter so no rust problems - not even on the undercarriage idk what you mean about the hood holes rivets are only in the bumper, the upper grille is done with zip ties. i'll rivet matching mesh into the upper when i gut the plastic fins out of it.
