a couple of harness questions>?
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
My swap is starting to come to a end but I had a couple of questions about the harness. On my ka/e harness by the ecu there were also 2 extra connectors, but on my ca harness there was only 1 extra and the 3rd was no where to be found. According to the fsm there's supposed to be one. Has anyone else ran into this? And is this 3rd plug needed? Also after connecting the harness in the engine bay area there were 3 plugs left over that I didnt know what they were exactly and where they are supposed plug to and if they are even needed.
Any help would greatly appreciated.
Thanks in advance, Wei
ka/e harness
This was where the 3rd connector plugged into.
Ca harness.
extra connector? needed?
extra connectors? needed?
thanks again.
Modified by anumeric at 4:05 AM 3/30/2006
c-rad
Car: 1991 Nissan 240SX w/CA18DET
plug by the manifold is for the stock boost control solenoid.... plug by the fuel filter is for ABS
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
That third plug thats found inside the cabin, just forget about it. When people do their SR swaps, their harnesses dont have that clip either
capowered240
Car: 90 240sx
I also have a harness question. Where the boost solenoid plug is there is a black wire with a ring connector. Does that wire need to be grounded?
anumeric
cool thanks for the help guys, if all goes well it should be done by this weekend.
anumeric
biosehnsucht
the 3? 4? i forget pin connector by the ECU in the first pic I'm almost certain connects to the cruise control.
Use the USDM KA and the CA FSMs and compare wiring for the wires to the cruise control to make it work. It should at least get some kind of tach signal, forgot what else.
Or, just don't hook it up.
