groundhogday1976 »
https://forums.nicoclub.com/groundhogday1976-u4144.html
Sat Oct 04, 2003 4:07 am
First, when I pulled my non-working power antenna out a few weeks ago, the geared plastic strip that goes into the motor was not on it. There was just a little plastic stub at the base of the antenna. I guess this means the plastic strip is stuck inside the motor. Can it be taken apart to get it out? Second, I'm due for an oil change and I was thinking about going to synthetic. My car has 151,XXX miles and doesn't use a noticeable amount of oil. Should I have my engine flushed first?
