A couple of dumb questions-need help!!
penbed51
Car: 1999.5 Pathfinder
I cannot find where my pcv valve and gas filter go on my 1999.5 Pathfinder.My old tired eyes have looked everywhere!
Also have a PO160 Bank 2 Sensor 2 code.What do I need to know about this code?
Also have been told to replace timing chain(belt?) @ 60,000 miles.Is that correct?
I bought this new in Jan. of 2000,has been a great SUV,she still looks new!!
Thanks
03Chillinkoot
Car: 2003 Nissan Pathfinder Chilkoot
the fuel filter should be just above the rear differential, i have the 3.5 it should be the same as the 3.3. not sure where the pcv is on the 3.3. P0160 is rear o2 sensor bank 2, you'll probably have to replace the sensor. Nissan recommends replacing the timing belt at 100,000 miles.have fun!
penbed51
Thanks for the info.Not sure but I think the pcv is passenger side under a hard plastic case.I want to make sure before doing some damage.
02pathy
look for the pvc under that plastic cap stuck in one of the valve covers can't really pic it right now but it should their with a tube going back to the intake mani if u find it pull it out and give it a shake if it rattles it is still good if it doesn't it is garbage but they r prob like $20 anyways
penbed51
yea,that is the plastic part I was refering to.not rattling,already bought one so might as well replace it.thanks for the info guys
