colincliff2 »
https://forums.nicoclub.com/colincliff2-u54836.html
Fri Oct 30, 2009 5:45 am
The door lock timer is fairly easy to remove (assuming you're ok with laying on the driver's side floor and reaching up under the dash). As I recall, it is a gray box (maybe 1" x 3") located right near the steering shaft. There is a smaller, dark brown box that sits right next to it. Both are attached to the same bracket, which is held in by a single 10mm bolt. Remove that and down it comes.
There are two part numbers for the J30 door lock timer. One ends in 70 and one ends in 77. I am not sure if the two are interchangeable. Every J I've come across in the scrap yards has had the 70 timer.
Yes all USDM J30s came with factory keyless entry.
Modified by colincliff2 at 8:54 AM 10/30/2009
