a couple mov files
Trigger
ok guys i figured i would make a couple mov files of the car so here they are mods are t3/t4 custom top mount mani frm Boostboy 3" exhaust from turbo back, and some nice jun cams and everything else is pretty much stock
http://vids.myspace.com/index....76442
http://vids.myspace.com/index....4&n=2
Modified by Trigger at 3:19 PM 7/2/2006
89'ClubK's
Car: 89' Nissan 240SX
Engine sounds healthy! I dig the Type X tail- lights (Originals).Did you see much gain from the JUN cams being a turbo car? Let me know, I've been interested in them. Thanks!
Trigger
i didnt see a big differents until i upgraded the turbo...with the stock turbo it ran rich but now she runs good if i could just get the code problem worked out
Tim
FutureDRFTer
Car: 1997 Nissan 240sx Se
that sounded awsome....makes me feel better about my upcoming swap.
right now im gathering info so i can understand more when my clip arrives
capwred
sounds and looks nice.i just got my running.got to get some tuning done and make sure all the bugs are worked out.
by the way can you post a pic of the engine ( air filter pipe) . im trying to fine a place to locate mine.
FutureDRFTer
i love the sound of your car.
i am a newb so....
was that a bov or wastegate? and which brand?
edit:sorry for 2 posts
Trigger
the was a RFL BOV and I will post some pics up later showing the engine but its very messy I got to clean everything up and figure out a mounting bracket for my air filter
Trigger
anymore feed back?
boost_boy
Trigger wrote:anymore feed back?
Congrats man and sorry it took a minute to respond on this one. I hear the happy cams, the engine sounds great, the car looks spectacular, but what code are you having problems with? Sorry, some posts I just don't look at, but it's nothing personal because you know I don't mind helping you, man. Let me know if can help you with this issue.
Dee
Trigger
thanks Dee. yeah those cams do make a difference but i am getting code 13 now and thats the temp sensor but i just replaced it with a new one a couple weeks ago and its throwing the code. I also am getting 34 which is knock and i did hook it up directly to the ecu wire 23 so i am thinking its a bad sensor so i need to get a new sensor and try that. slow since you asked when i first start the car it idles aroun 450 rpms and it pulls no vacuum but as soon as temp gets half way it jumps to 1500 rpms and pulls great vacuum. I am thining i have a leak somewhere around the AIV..any thoughts on that stuff?
