thanks for allowing me to sully your ranks!
I need to get my 2002 I35 in for transmission maintenance, and will probably do the drain and fill, instead of the flush. What fluid does everyone recommend? I noticed that Amsoil ATF has a synthethic fluid, so I'm thinking this may be a possibility?
Also, I've got a bit of a clunk going over bumps on the front passenger side, which wasn't relieved by installed new struts all around. In reading, i've noticed more than a few people saying that they found it was a weak motor mount, and after changing it out, it went away. I'm planning to order the motor mount for that location, but wanted to ensure I order the right one. Here is the one that I found, that i think is the right one:
http://www.partsgeek.com/catalog/2002/i ... mount.html
Lastly, I plan on buying the part and having a local shop owner that I know install it for me. What kind of labor time am i looking for this part?
Thanks for any help, I appreciate the input! Looks like a great forum to be a part of.
Doug
