Steps on dong this correctly1) Run the motor for about 5 mins or so untill it is warm.2) Turn it off3) Unplug the fuel pump fuse and open up your gas tank cap4) Start the car untill it dies completely5) Disconenct The plug on the distributor or Unplug your ignition coil6) Install compression gauge at #1 cylinder7) Crank motor for about 8-10 seconds while holding the gas pedal down with your foot.8)record numbers (helps to have a second person, but can easily be done by yourself)9)repeat steps 6-8 for each cylinder7spokenightmare wrote:i dont believe the motor is "thrashed". it runs fine... just smokes a lil at high rev. dont see any real power loss out of it... im just getting weird crap as i try to look into it.
i was hoping maybe there was an explanation such as timing or a ka specific issue that would explain it.
maybe i checked the compression wrong? heck i dont know.
i have a hard time believing that my motor is trash when it runs fine and has no real issues while im drivin it.
the reason im using multiple threads is because i cant seem to get anyone to respond... either everyone here has no clue (hard to believe) or i must be asking the wrong questions
stfu d!ck I said that alreadyd!ck wrote:im willing to believe that you performed the compression test incorrectly, but then again i could also go for the theory that you have a tired motor from your description of the symptoms.
it smokes and bad compression is a dead giveaway for bad rings causing blow-by.
I would say it has sunk in for people. I just put down the steps so that in the small chance he did it wrong he would know. 120 across the board....thats major power loss from a healthy motor.d!ck wrote:i know you said it before, and so did a couple other people. i dont know why its not sinking in...
Look here "dood" he did it wrong the first time like I had thought.neverlift wrote:clearly it is not down on power you heard dood its still making 200 whp lol.
I think he is mistaken a maf system(that is constantly monitoring and adjusting afr) compensating,for the less comp. And yeah it will feel like the power is the "same",but trust me its not,go drive a 240 with only 20psi more sacross the board. YOu will feel it.try some restore
