DominickJ30 »
https://forums.nicoclub.com/dominickj30-u24762.html
Mon Dec 18, 2006 1:25 pm
Trans oil, I would go with mobil 1 synthetic, but that can get quite expensive, close to 100 dollars just for the fluid. The J take about 9 quarts so...
Cleaning the intake system is performed with a fluid cleaner(BG intake cleaner) and a reservoir with a valve and hose on it.
If you get the BG intake kit, make sure to get the reservoir. It comes in handy even after you do your own car.
Now to explain it a little.
You fill the reservoir, then with the valve closed connect the hose(with atomizing tip) to any of the vacuum lines on the intake manifold. You want to do this with the car running FULLY warmed up. The hotter the engine the more you will clean.
Now slowly start opening the valve to allow a very slow flow of fluid. I usually do it enough to hear the enigne hesitate a little and back off a bit.
Wait until all the liquid is gone and go out for a nice drive on the highway. Now beat the hell out of the car, like redline starts etc. You will see all the carbon buildup smoke out of the tailpipe.
Then back to your garage and change the oil.
You would be surprised how much this helps with rough idle rough accel etc. You should be plesantly surprised.
