A/C Works - Fan doesn't - Any suggestions?
deosingh
Car: 1989 Nissan 240 SX
I have an 1989 240 N/A. When I slide the fan switch to the 1, 2, 3, or 4 position, it doesn't seem to work whether the A/C button is on or off. I think the A/C still works because when I hit the A/C button, I can hear the A/C fan turn on and the button light turns illuminates.
Also, while I'm driving, if I hit a bump and the fan slider switch is in the 1, 2, 3 or 4 position, it turns on blowing air for a short time, then turns off until I hit another bump. Similarly, if I hit a bump and the fan slider switch is in the 1-4 position and the A/C button is on, cold air is blown out of the vents.
This indicates to me a loose connection somewhere, but I don't know where to start looking? Anyone have any advice or an electrical schematic that would be helpful?
Thanks.
ur2nrvs
Car: 180sx
Have you checked the fuses under the hood? Your wires might be melted together and shorting itself out. Just a suggestion though.
deosingh
Yah... check the fuses. Things look good there. I'll double check the wires though. Could this be a switch relay issue?
ur2nrvs wrote:Have you checked the fuses under the hood? Your wires might be melted together and shorting itself out. Just a suggestion though.
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
relay or blower motor itself may be going bad.
deosingh
does anyone have an electrical schematic of the cooling system that they can post?
not sure where to look to find the relay or blower to troubleshoot.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
The blower is located behind the glovebox.The white thing with the plug coming out of it is your blower motor resistor.
italia16
Car: 1995 240SX
I had a similar problem with my 95 240SX. The air would not blow unless the dial was in position 4. I replaced the blower resistor for $25 and it solved the problem. Good luck.
