YR240 »
https://forums.nicoclub.com/yr240-u59227.html
Mon Jun 23, 2008 3:38 pm
I checked, and no results, which is the booden cable? I went through every wire to make sure they had good connection, they did. Is it possible a recharge would help? The compressor comes on and stays on like I said so I am not sure. If the compressor is on, the the refrigerant should be running through the entire system, right? or is there some kind of bypass the diverts the refrigerant from entering the evap? If the compressor is running and everything, shouldnt the evap be getting cold?
