A/C turning off when reving high rpm
zieszx
Car: 1991 Nissan 300zx NA
Good day,
..well in a nutshell: It began yesterday, all of a sudden.. when I first turn on the car idling AC turns on/works fine, when i rev to about 4.5 rpms it almost seems as if it loses power(the AC controls/fans). When i begin to drive: starts shutting off when i switch into lets say..3rd gear or so, when rpms are getting higher... once i drive for a good while it just simply stays on even after switching up/down gears. before i forget, if its off and im driving, if i go to neutral and hold my clutch in, it turns on..and back off when i go back into gear..weirdest part to me. Ive checked fuses in the kick panel, nothing seems ..out of whack. no error codes either. Advice? Thanks in advance.. :confused: :confused:
NolimitZ32
Short somewhere?
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
make sure the Freon is full.
Your compressor clutch may be going out.
zieszx
thanks for your prompt replies. Actually, turns out it was my alternator which had gone bad.. replaced it myself, turned out great.. was like a 1hr overall job. Easy DIY kinda deal.
