1) AC compressor clutch engages after turning on AC switch
2) System is full of freon
3) When AC compressor clutch engages both fans are blowing. After Car warms up.
4) Checked relay/fuse
5) Heater works correctly all vents blow in the direction via the climate control knob.
I was going to run Consult 3 and the laptop took a dump I guess 2 much moisture. I dont even know If I could pull codes off the system?
6) No check engine lights, Car runs like a scalded dog.
Any gurus out there... I am breaking open my service manual after posting this. I will also follow up on the solution as I did with my previous 350z issues/build.
Thanks for any Input.
