This is a good chart to go off of...
https://www.google.com/url?sa=t&rct=j&q ... 5608,d.aWc
134a runs 2psi lower than r-12 equivilant on the low side. Runs 10% higher than r-12 on the high side. Take note of the ambient temp when charging. Make sure you use a vacuum pump for at least 1hr, longer if moisture got into the system.
From experience, it will make it cool when not driving, but not ice cold. When it feels cool or if using a temp gauge, if you can get it below 50 degrees, leave it alone. I think I had my gauge at 40 low and 190 on the high side at roughly 85ish degree. When you get close to 35 and 170, let the AC pump cycle a couple times before adding anymore. If you do add more, little at a time. Overcharging will make it blow warm.
I did also realize my electric fan was not turning on when I turned on the AC. When it did turn on, it did a better job cooling the air, but not sure if it is suppose to turn on when the AC is cycled on.
