EikichiAce wrote:thnx guys. but 1.4 and 1? do u know if theres anything out that lowers at least 2 inches? im not sure if an inch is that noticeable of a drop
it depends on what type of wheels you have. IMO, the drop doesn't appear to be very dramatic when viewed on the stock wheels and even on 19" wheels. The reason being is that with those sized wheels, the tire walls are still rather large. The larger wheel you get, the more the wheel well will be taken up with rim as opposed to tire (when keeping the overall tire diameter close to 26.3")... thus a 20" wheel without a lip on 245/35/20 tires will NOT look the same as 17" wheel with 215/55/17 tires on it!
So given a particular wheel/tire combo, the look can be dramatically different!
