I'm now focusing on my A/C problems for the 99 Q. Unfortunately I have only a little knowledge on the subject.
I recharged my A/C with A/C Pro and it lasted my trip to Austin for the weekend, but by the time I got back home about 3 days and 500 miles (round trip) it started spewing steam from somewhere under the hood... It's typically about 100-105 degrees out here after June, so the need to fix it is urgent...
The first time I noticed it, I was inside the car with the sun shade up sitting in the parking lot on my lunch break eating. I heard a large leak sound coming from the brake pedal. My ABS light is on so I thought it was my brake booster freaking out. I pressed on the brake and the leak stopped. I looked at my Temp Gauge and I was 3/4 the way to HOT. Typically I stay right below halfway... So I popped my hood and looked on the ground for coolant. Saw none, then I noticed that there was a LOT of green refrigerant on the drivers side of the engine bay.
Questions:
I am assuming that there is a large leak in the A/C line?
Why would it not constantly leak?
Does a bad Expansion Valve cause this?
Any other ideas?
Thanks
Javin
