jnever1 »
https://forums.nicoclub.com/jnever1-u168056.html
Wed Jul 11, 2012 3:36 pm
My thanks for the replies but neither addressed my concern: Based upon data given, have I overfilled my system to a point where I should depressurize appreciably?
While I certainly agree that venting to the atmosphere is not PC now-a-days, I also feel that it is ridiculous to pay someone $80-100 to lift my hood, hook up two lines to my car using quick connects, push some buttons on a digital key pad and then enjoy a smoke or double flag time. I spent $25 on the kit I used and half of that was for the transfer tool.
I know from personal experience that the hardest part of the self-contained evac/recharge station process is looking up how much refrigerant to key in to the machine. This is the part I am having difficulty reconciling with respect to a less-than-clear FSM. Exactly how much refrigerant does my Q require? The manual is sending me mixed messages.
I know enough about phase-change thermodynamics to do my own calculations to enumerate how much R134a I have in my system, given a gauge reading of limited precision. PV=nRT is a good enough estimate for this application in my opinion.
With this in mind, it is worth noting that I haven't had my a/c serviced in over 7 years. This is plenty of time for a few ounces of 1,1,1,2-tetrafluorothane to sneak past a couple of rubber service port o-rings. Since I'm not seriously over the upper threshold of the FSM limits, given atmospheric conditions stated, I'm just going to assume that my Q was probably close to 10 oz low and that the can could not possibly transfer 100% of its contents.
Observations my assumption is based upon:
A/C worked before adding refrigerant (system holds at least some pressure)
A/C worked up to a chill eventually, it simply took a LONG time (mass of available phase-change medium probably low)
A/C improved after refrigerant added (probably added a small amount more than ideal)
LowPressure reading is < 35 psi @ 650RPM on a hot, wet day. (system at upper end of spec)
That said, yes, complete evac (so that the assumption of mass refrigerant = 0 can be reasonably made) followed by fill to spec by weight would have been the best option.
I did not choose that option.
Regardless, since improvement has occurred I will take my Q as improved and consider this issue resolved, if only by happenstance.
