A Paratroopers 300zx wrote:Just a friendly note... The expansion valve is located in a box under the dash next to the heater core on the passenger's side. The whole dash and cross member have to be removed to get to it. I would strongly recommend sourcing all other possible problems before looking at the expansion valve, as it is about a 10 hour job to replace.
Actually, the box will come out by itself. Once you remove the glove box and its support brackets, discharge the system, crack open the system, remove the seal in the firewall it will pop right out. This was done intentionally to allow the system to be repaired.
But, the expansion valve can only keep the clutch from turning on if it leaks.
