A.C. & Radio Display Malfunction...HELP
SuperCoupe400
Car: Wife's: '03 G35 Sedan + '06 FX35 / Mine: '93 Lexus SC400 + '06 Lexus LS430
My (wife's) '03 G35 is having some electrical issues. Periodically the AC will be on (from the time the car is started) and not shut off or even respond to driver input. Also, the radio control backlighting will stay on (with radio off) and not respond to driver input.
Neither of these accessories is ever left 'on' when the car is turned off. My wife makes a point of always turning off all accessories before shutting the car off (though, I keep insisting to her that this is not necessary with the way cars are engineered these days).
Has anyone experienced this phenomenon before? What's the cause? A board about to go out? Is the solution something I can implement myself?
Thanks a ton.
joe603
Car: 2014 Durango R/T
Sounds like the dreaded radio problem with the 03-04 G's...
If you have an extended warranty, take it to a dealer ASAP...if not try this site: http://carstereohelp.com/infiniti.htm
zozoka1212
Car: 08 Infiniti G35x
Joe that was fast. 6 minutes.
zozo
SuperCoupe400
Thanks, Joe.
SuperCoupe400
joe603 wrote:Sounds like the dreaded radio problem with the 03-04 G's...
Thanks.
I've got no extended warranty, so I'll be doing the work myself. Absent of having no functional AC or radio, will prolonging an immediate repair cause damage to any other components or function of the car?
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
i had the same problem... i had to buy a new radio/cd unit and that took care of the problem... other than taking the fuse out for awhile or removing the negative terminal from the battery for the radio to reset itself, there are no other short term solution... i see no other problems should you decide to forego repairs for awhile other than the a/c turning on by itself and no way to shut it off ( i could be wrong here ).. my advise is to disable the radio and a/c by removing the radio fuse...
joe603
Here is another site that specializes in factory radio fixes....and they are a NICO sponsor
http://www.sound-repair.com/
adren77
Car: 2004 G35 Laser Red Coupe 6MT
would http://cgi.ebay.com/METRA-99-7...wItem plus and after market head unit solve the problem?
joe603
Well it says it has the AC controller...it looks like it would work. To go aftermarket, you have to replace the bracket, AC controller, and finisher plate.
Here is a site that allows for a double-din aftermarket deck:
http://www.grubbsperformance.c...ERIOR
Georgeb
IF you are still having a problem wit your unit we at Short Circuit Repair can help you. We are also NICO sponsors.
Email me if you have any questions.
[email protected]
