DeeZX »
https://forums.nicoclub.com/deezx-u100654.html
Thu Aug 05, 2010 12:28 pm
Try to see if the fuse will blow without the electrical connector plugged into the compressor when you turn the A/C on. If it does It then, there might be a short between your compressor and the compressor relay. If you have access to a meter that can test continuity, test between the connector, (the end you connect to the compressor) and ground, If you get a tone from the meter, there is a short to ground between that connector and the relay. I would then check for wire with chafed or melted insulation between those two points.
-It may even be a bad relay.
