kouki-gymkhana »
https://forums.nicoclub.com/kouki-gymkhana-u9464.html
Fri Jun 27, 2008 4:42 am
I've been running A/C on my RB25 s13 for 2+ years with no major issues. I ended up using an RB26 compressor with modified KA lines that I had fabbed up at an A/C shop. My wiring guy did the wiring ages ago but from the looks of it, it's not rocket science. The system cycles off/on just like factory.
As for cooling, I have FAL 12" 210s mounted as pullers (I modded the upper and lower rad supports for more clearance) and they seem to be adequate. I also have a pignose A/C fan mounted on the front of the condenser as a pusher. (Yes, they suck MAD amps, btw) With the A/C off on a hot day, the temps stay between 80 and 85C. Mind you, this is in the jungle heat of South Florida. With the A/C on, the temps stay between 85 and 90 and if I come to a quick stop at a light after cruising for a while, they edge up to 93 or so. Yes, it's hot...but given the fact that I have a huge FMIC, condenser, thick *** Koyo rad and then the fans, it's not too bad. I'm thinking about switching to a silvia front end solely for the increased frontal area to aide with cooling or a 180sx kouki bumper with the licence plate cut out and some group N vents thrown in there too.
Yes, I'm running a bottle of water wetter, have a nismo Tstat, and have extensively bled the cooling system. Headgasket is good to go because I changed it last year and have only driven about 150 miles in the past year.
