far raf »
https://forums.nicoclub.com/far-raf-u272099.html
Mon Aug 20, 2018 9:16 am
I find this problem description difficult to understand. From what I gather, your heater is on simultaneously with the AC, if AC turns on at all.
So let's rewind: when you switch on the AC, does the compressor turn on? Do radiator fans turn on simultaneously? What mode is your AC control in (floor, windshield defog, top vents or floor and top vents)? Does the blower motor work on the front? Does the blower motor work in the rear? What is the rear AC mode (R, 1-4 etc)?
And most important, did you download the FSM and can you follow the AC troubleshooting steps in it?
