evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Jun 04, 2007 8:51 am
sounds liek the safty valve and sounds like it's blown, most a/c systems have a little valve designed to fail at a specific pressure, so I suppose your gonna need a new valve and then you get to find otu why it blew, you'll need a full manifold gauge set to determine high and low pressure levels as it's charged to determine the problem, if I had to guess I'd sau it's the expension valve, located inside the a/c box under the dash, huge PITA to get to and replace
