A/C performance booster
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
I suspect that I may have left some moisture in my a/c system when I recharged it last year having used a cheap diaphram type vacuum pump. I was wondering about adding a moisture remover product. It come in a small screw on canister and the directions say it contains methanol.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
I would vote no, if the big boys don't use it us little boys shouldn't either.
DAEDALUS
You would have to open up (evacuate/recharge) the system to install it. If you're going to do that, you may as well replace the drier ($60), which removes particles and moisture, and which does not require any modifications to the system. It's just in front of the battery.
Q45denver
1990 Infiniti Q45
Actually the product injects directly into the system and doesn't require it to be opened. The directions state that it converts the water in the system into a non-hydroscopic substance. I bought it at Pep Boys a couple years back.
PalmerWMD
Car: 2004 350Z
Did you put in a new dryer when ou performed that work?
If not a new dryer will change thos problems.Either way acting quickly is of the essence.
Fred..:)
