ok so i had to look up these nissan sizes based off a sentra fsm. I will show you the fsm that tells the o-ring sizes i think it doesn't matter what nissan year yours is as long its r-134 possibly it works for r12. Since my infiniti is a 1996 i think this might be a good reference guide
http://www.nicoclub.com/FSM/Sentra/2001_Sentra/ha.pdf you will see on page HA-5 what im talking about.
So here's the chart according to the FSM
nissan o-ring size / Diameter / width
8 / 6.8mm / 1.85mm
12/ 10.9mm / 2.43mm
16 / 13.6mm / 2.43mm
19/ 16.5mm / 2.43mm
the FSM also contains part numbers. Like i said this might be a good reference guide for those doing their own a/c compressor not sure maybe someone can chime in.
also if buying a compressor and it needs oil (usually new one comes with it already filled but lets say your getting a used one that some maybe missing just drain it and fill it with oil according to vehicles spec)
G20 is 6.8 oz of oil. now the fsm for the g20 calls for some oem oil (part # klh00-pagr0) but this reference guide below say PAG 100 is the same as that
Also has the type of oil for other nissan/infiniti vehicles plus more
http://www.napabeltshose.com/downloads/ ... ew=napa_hc
