amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Wed May 23, 2018 3:41 pm
I worked in OTC auto parts, and A/C was a huge problem. People never work on them right nor as completely as the job requires, and that very commonly includes the mechs as well. A/C typically requires several parts when the systems come apart or the job comes undone very shortly after doing it. I have done all of my own A/C work my entire life (40+ years) and can shortchange at times when needed but it is extremely risky and why the OEMs won't do it, they do not accept only a partial fix there as it gives bad flak back on the company. As well, the entire car industry has been going to a 'parts unitizing' theory, where common associated parts are now made or considered together as 'necessary' even though not really. They are simply lumping them together to make buyers buy whole packages of parts to only get the one smaller part needed there. Like specialty one-off bolts, they may only be gotten by buying the subassembly they get used with. The idea being to push parts sales profits way up to make up for lagging car sales.
I went to Rock Auto and the compressors there were packaged ('kits') along with the expansion valves (your likely electrical control) and expected to buy both and similar to when I sold compressors, the buyer not receiving any warranty at all unless the compressor, accumulator or dryer, any filter needed there, the metering device, and often even the condenser were all changed at once. Why? Any trash getting into one small part means there is likely trash in the system to tear up other parts in short order, A/C has to be kept perfectly clean inside or the system will go down again and again to cause whoever warranty issues into bankruptcy. The people working on them I spoke of above come into play there, they refuse to clean all parts as needed trying to cut costs and the part manufacturer must then require them to buy ALL parts in protection from that. The bigger parts buys then protect somewhat by giving more money throughput to cover excessive warranty issues.
Often A/C can be fixed for as little as a couple dollars or with only one part, I've done it bunches, but the larger market tends to screw that up in search of the massive buck there. The system issues need to be correctly diagnosed as well or the costs will go up hugely. OP may well be there right now.
You can go rogue like I have for 40 years and say screw any warranty to only buy one part to fix successfully to go on, but if you gotta have the comfort of that warranty you gotta play their game. I for one don't. I AM my own warranty there. But then I have never taken a car anywhere ever to be fixed by others, I do it all. Most will not have that option though, I am definitely the odd bird there.
