Seems highly redundant and wasteful in the grossest sense to discuss how something works that is common to almost every 1955-1993 vehicle on the road.
Specific variations to Nissan would be a valid use of space.
As to Freeze 12 besides the other problems the Calsonic variable displacement compressor is internally set at 28 psi low and Freeze 12 needs 19-21 psi to duplicate the EXACT same cooling. That could result in an up to 8-10F warmer temperature [depends]. See belowhttp://
www.autofrost.com/autodisc.pdf
"Beware of "quick 'n' easy" retrofits being hawked by all kinds of places. You might get a mechanic saying that conversion to 134a is just a matter of vacuuming the system and running-in a charge of 134a. RUN. Or, you might run into someone who wants to replace your R12 with "FR-12" or "Freeze-12" or "Frigc". These three (and several others) are simply 134a with an additive that makes it slightly less violently incompatible with 500sus mineral oil. RUN. You might also get someone who wants to put OZ-12 or HC-12 into the system. These two are blends of isobutane and isopropane. They work very well in R-12 systems, and have no oil incompatibility problems. BUT, they are flammable. To what degree this concerns you is an individual matter.
It's not as clear-cut as you might think, because *all* refrigerants are blended with oil in the actual system, and ALL refrigerants are violently flammable under catastrophic system breach conditions (refrigerant rushes out, creating aerosol mist of oil--BIG flameball whether it's R12, R134a, OZ-12, or Freeze 12, whatever). These hydrocarbon blends also are super cheap (about $1.25 for enough to charge a few systems). "
