A/C issue
trebor66
Car: 2012 Nissan Frontier
Has anyone else had this issue. With the A/C already switched on at the time the truck is started the blower starts to blow and with in a few seconds the lights on the A/C controls go off and the blower stops. Then with out touching the controls the lights return along with the blower and yes blows cold air . Should I be looking for a problem. I'm in Texas no fun with no A/C ,it's working just don't want it to stop. :wtf2:
Q451990
Found this... not sure if the symptoms are exactly the same, but it sounds pretty close.
https://www.bobistheoilguy.com/forums/u ... /3810388/2
If you find that your fan resistor is bad, I would be sure your cabin air filter isn't clogged - creating a low airflow condition.
carldu
Car: 08 Titan
Maybe the connector leading to the pressure switch went bad.
