VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Fri May 22, 2026 5:48 pm
Couple things. First, I think there's a little confusion here. You say at one point that the compressor won't kick on, but at another point that the low side pressure is high. The pressures mean very little when the compressor isn't engaged, so which is it?
Second, I'm assuming you have an Auto system and not Manual, since there's no Intake Sensor on a Manual system. There are actually 3 different temp sensors which can disable the compressor on an Auto system. There's an In-Car sensor located behind a grille at the driver's right knee. None of them, In-Car, Intake, or Ambient can read "Alaska" or the compressor clutch won't activate. "Alaska" is 5V, all the sensors should read some "middle voltage" and not 5V or 0V (0V is "Sahara", so that probably isn't your issue). You can check the intake sensor at the pigtail connector on the passenger side of the HVAC box, it will be a 2-pin white connector with Pink and White wires. You probably need to pull the glove box to see it. White is grounded inside the A/C Auto Amp, Pink is signal. Backprobe Pink and if it reads 5V, either the sensor or the ground wire is open-circuit. Same procedure for the In-Car, drop the left lower dash and backprobe the sensor. White is again ground, Green is signal. The dash will tell you if the Ambient works. If the other two read normal middle voltages, the problem isn't a temperature sensor.
The pressure sensor is a different animal, and the wires don't end at the IPDM, they go through the IPDM to the ECM. The ECM is the shot caller. Normal static signal on the sensor (Violet wire) with the connector backprobed is about 1V at room temperature, about 1.5~2V with the compressor running. Orange is 5V supply, Sky Blue is ground. Most decent scanners can pull up the refrigerant pressure as streaming data. The ECM will cut compressor operation below about 20 psi (0.2V) or above about 400 psi (4.2V).
Lastly, the compressor on the Auto system is a swash plate type (the Manual uses a traditional cycling clutch). Swash compressors change the piston stroke to move more or less refrigerant volume according to demand. This is done using a solenoid (ECV) built into the compressor and run by the A/C Auto Amp (the Amp is located underneath the radio on a shared bracket). At the ECV connector, Blue should be constant 12V, Sky Blue should be 12V when the compressor is disengaged and a "middle voltage" when the compressor is running. Swash plates almost always stick at the bottom (minimum flow) when they fail, so there's an easy test for a bad one. If the system makes good cold with the blower on the slowest setting but the cold goes away when you crank up the blower, the culprit is a stuck swash preventing the compressor from moving enough refrigerant to meet demand. Note that an open circuit to the IPDM can also cause a dead swash, so make sure you don't have a bent pin at the connector.
