jboydo »
https://forums.nicoclub.com/jboydo-u76999.html
Sat Dec 01, 2007 11:27 am
No, I never did. I tried replacing a few fan relays ($60) under the hood, but to no avail. I didn't really know where to go from there so I got a bit creative and rigged a new circut going straight to the fan. I noticed the fan runs at 15 amps. So I tied into the cigarette lighter's existing circut (also 15 amps) in the center console, included a simple on/off toggle switch within the same circut, unplugged the existing underdash wiring from the fan and ran "temporary" wiring to the fan from the toggle. (I removed the cagarette lighter's insert and just put the switch there) My fan operates at either full blast or not at all since the installation and I had to explain to my wife that the climate control should never be turned on unless the fan is on as this could cause the A/C system to freeze up. It can be a bit irritating at times because of the volume of airfow....but hey, I got mad windage now. Plus I only spent about $15 to fix it. It's worked fine for the past 2 months, problem now is.....it works just good enough to leave it alone and not fix it the right way when I actually do find out what happened in the first place. haha Let me know if you ever figure it out what caused the problem and how to fix it. (I don't envy your cold temp.) Good luck in your pursuit!
