A/C hot
Roguegirl86
Car: 2009 nissan rogue awd
Im woundering if i should recharge it but i was told to get my presure levels checked before ,for it can couse a problem... How do i do that and wich levels should it be at even tho hot air is comming out
Can i purge it then do recharge :ohno:
Oatmealman
Car: 2011 ford f150 fx4 5.0 master race
pressure should be around 25-45 dependent on temp for the lower side and 160-250 for the highside again depending on temp
If you're unsure of about a/c stuff either do some reading up to educate yourself or pay a shop to do it(me being a tech I would prefer you bring it to a shop) just because I hate fixing other peoples screw ups.
Roguegirl86
Ok thanks,my husband purged it and pressure went down and started coming out cold again...hopfully is stays that way,nissan has always been a dealer thing(expensive)....
WDRacing
Glad it seems to be working.
Welcome to Nico!
JTR32gtst
Been a while, but I think if head pressure is high at the compressor, that is shutting it off. High head pressure could be a block at the condensor or the fans not working properly? A/c experts can chime in, but if it is building pressure, relieving it may only temporarily fix it?
I would take it in and have them check it out.
Roguegirl86
Thanks,ill def keep an eye out
