RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Fri Sep 07, 2007 8:04 am
Thanks for that link......I think I figured it out.......the S12 pulley is a v belt pulley......and I tried to use a 3 rib serpentine belt on it to match the tensioner, and crank pulley. Thought it would work. When I first cranked up the car everything was fine.....as I turned on the ac and let it idle, the clutch engaged and worked for about 15 secs, then I heard a thunk sound, and thats when the clutch started engaging, and disengaging every 1 sec or so. Upon closer inspection today, the belt had turned itself part way inside out.....with a 2-3 inch gash in the center of it. I just ended up cutting the belt off. For kicks after I cut the belt off, I cranked it back up, and turned on the ac......the clutch engaged, and stayed engaged......so I think my problem was the belt was about to self destruct.I have a z31 serpentine pulley that fits the ca18et compressor, but it's offset from the tensioner, and crank pulley. Maybe the skinny 3 rib belt will allow it to work......I know the fatter ac belt won't. Anyway, back to square 1
