A/C HELP
avengerx45
Car: 1993 nissan 240sx se convertible
Hey guys, can anyone tell me where the fuse for the a/c compressor is located on my 1993 240sx vert, a/c stopped working and the button on the control head no longer lights up so i'm assuming it's the fuse, any help with this would be appreciated, thanks
nukeone
You have several checks to make. 1st - As you mentioned, check the fuses. Yes, fuses. There are 4, all located in the fuse box at the driver's side kick panel, two for the blower motor, one for the blower relay, and one for the A/C switch. If you don't have power, maybe you will get lucky and find that it is simply a blown fuse. If you don't have a blown fuse, you then have several relays that you can check, including the max cold relay, the blower relay, the A/C relay, and the condenser fan relay, not to mention the blower fan speed resistors!! Check the fuses and let us know what you find.
