nissanconvert »
https://forums.nicoclub.com/nissanconvert-u33061.html
Fri Jul 14, 2006 5:12 pm
Huzzah! Working r12 a/c for $120 and a scar(the exhaust is hot!!)Recap:a/c light did not come on or clutch or fan either.High + low side had 20psi when off.
After reseach this is what i came to conclude.The system is old and seals are likely dry, whe i tested the pressure it was dry freon coming out. Since it was holding pressure there is no massive leak.
Optiions:Recharge r12 or retrofit 134a or use alternative.
Decision: recharge r12 for best chance. using an alternative works less, costs more and makes it unfixable later by any tech or shop for libility reasons. REtrofitiing properly is expensive and time consuming. $600+. The auto parts store retrofit in a box is baloney, the oils are not compatible, the system isn't designed for it and it will likely break down the road costing more. Recharging r12 is fairly easy and nto that expensive once you know what you're doing.
1st step, get freon. If you don't have r12 on a shelf you need to buy it. It is legal to buy and use if you have the EPA license for it. I got the license by taking a online test. It's $20, 25 multiple choice question and takes 1-3 hours depending on how you study. Also it is open notes. 21/25 gets you a pass. I did it in one evening. Now you can go on ebay and buy the r-12, hoses, gauges and tap. One seller has recharge kits that work great. $90 +13 shipping gets you 3 12oz cans, toyota 1.4oz swash plate oil(240sx is swash plate compressor) and tap/gauge. I borrowed a good hi/low pressure gauge to save money.
Thats 120$ including certification, which is less than valvoline charges to top off r134a!
I used 2 and 1/8? cans of r12 and the 1.4oz oil to get the system up to pressure. 148psi high/40psi low side, ambient temp 72, humidity 100%(raining). With full a/c on recirc mode i got 40 deg. F in the center vent. Good enoguh for me since it never worked before. THe high pressure is likely too high and low pressure is too high according to the manual but the system is 14years old and this is the first time i've worked on an a/c. I had to jumper the low pressure switch to get it running to take the first 2 cans. It the 2 wires coming off the top of the can with the bubble sight.
Look online if you don't know how to charge the freon (only low side! with can up NOT UPSIDE DOWN!) Took 40 minutes per can i guess for me? Bleed the fill hose lines to get rid of air between can and system. etc.etc.
Hope that helps. You too can have cold a/c for relativly few dollars and done in one afternoon. greatest part is its still origional so if it goes bad later you're not stuck. You can still convert later if you want.
I'll be gone until july 26th and can't get inet so if you have urgent question i can't help. If it can wait, just shoot me an email and i'll help as best i can.
