dan4010 »
https://forums.nicoclub.com/dan4010-u89378.html
Tue Jun 28, 2011 11:49 am
I'm having issues with my '93. just replaced the compressor about a month ago. When I drive the car in the morning, I have vent temps in the upper 30s, very comfortable. In the afternoon, during the heat of the day, vent temps are in the upper 50's which is not enough to keep the cabin cool in FL. Also, when I engage "auto" to start the A/C and begin cooling, the display indicates that both floor and upper vents are blowing with full fan. Is this normal in the Z32 when it senses its hot in the car? I've only known cars to blow out the upper vent when trying to cool and the lower vents when the heat is engaged. In the morning, when its cooler and I get the colder vent temps I mentioned earlier, only the upper vents are blowing, like I would think is normal. Pressures are good and its fully charged, no leaks. Vent temps don't vary much between idle and hwy speeds. Mechanic said I should think about replacing the expansion valve and condensor too. I'm looking for other possibilities. I don't want to spend $1400 to replace those until I've ruled out other less expensive possible solutions. Could it be the cabin temp sensor above my head? It's quiet, unlike in other threads where it was replaced because of bad bearings. Help. Thanks.
P.S. yes, I've searched and searched this forum.
